Write own simple driver
Hi all !
To answer all questions about writting a driver in uClinux, I create this topic to collect all solutions. Please share all !
If your device type is:
[uCLinux USB interface]<--------------USB cable ----------->[your device here]
And you want to write a driver for it.
First, There is a struct usb_driver in the kernel
//location: kernel-2.6.x/include/linux/usb.h struct usb_driver {     struct module *owner;     const char *name;     int (*probe) (struct usb_interface *intf,        const struct usb_device_id *id);     void (*disconnect) (struct usb_interface *intf);     int (*ioctl) (struct usb_interface *intf, unsigned int code, void *buf);     int (*suspend) (struct usb_interface *intf, u32 state);     int (*resume) (struct usb_interface *intf);     const struct usb_device_id *id_table;     struct device_driver driver; };
In your driver application, you declare:
static struct usb_driver myMotor_driver = {        .owner =        THIS_MODULE,        .name =         "usbmotor",        .probe =        motor_probe,        .disconnect =   motor_disconnect,        .id_table =     id_table, }; //The id_table variable is defined as: static struct usb_device_id id_table = {        { USB_DEVICE(VENDOR_ID, PRODUCT_ID) },        { }, }; MODULE_DEVICE_TABLE (usb, id_table);
When the driver module is loaded, this motor_driver structure must be registered with the USB core. This is accomplished with a single call to the usb_register() function:
retval = usb_register(&motor_driver); if (retval)        err("usb_register failed. "            "Error number %d", retval);
Likewise, when the driver is unloaded from the system, it must unregister itself from the USB core:
usb_deregister(&motor_driver);
All processing is in motor_probe() function ( using usb_control_msg() kernel function ) ...
but if your device is standalone ( ie: connected via some pins on the altera board ), how can you do ?
//location: kernel-2.6.x/include/linux/device.h struct device_driver {     char      * name;     struct bus_type  * bus;     struct semaphore    unload_sem;     struct kobject  kobj;     struct list_head    devices;     struct module      * owner;     int    (*probe)    (struct device * dev);     int  (*remove)    (struct device * dev);     void    (*shutdown)    (struct device * dev);     int    (*suspend)    (struct device * dev, u32 state, u32 level);     int    (*resume)    (struct device * dev, u32 level); };
what steps or what functions to :
- Delcare my device ( Address of device, port ... )
- Register it
- Processing data or control
- Deregister
Thank you very much !
OneNet
Good start. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
