I construct a sopc project in quartusII 4.1, and I can run any example on my board!
but I contruct the same sopc project in quarutsII 5.0, when I run the hello_led project in niosII IDE, the console give me such message: Processor is already paused Reading System ID at address 0x00301838: verified Downloading 00200020 ( 0%) Downloaded 1KB in 0.0s Verifying 00200020 ( 0%) Verified OK Leaving target processor paused but when I run the hello_world project in niosII IDE, the console display: Processor is already paused Reading System ID at address 0x00301838: verified Downloading 00200020 ( 0%) Downloading 00210000 (72%) Downloaded 89KB in 2.3s (38.6KB/s) Verifying 00200020 ( 0%) Verify failed Leaving target processor paused why quarutsII 5.0 can not work??Link Copied
What version of NIOS II IDE are you using ?- Mark as New
I think it is due to your SOPC system.
The problem appears when the cpu cannot work. And there are two reason may cause the result: One is the system you creat, mabye something wrong is with your system;and another may be that your FPGA configuration is destroyed, a new configuration is needed.- Mark as New
I use niosII 5.0 and quartusII 5.0!
but hello_led is successful, and hello_world can not work! it is very strange !!!!!!!!!- Mark as New
<div class='quotetop'>QUOTE </div>
--- Quote Start --- but hello_led is successful, and hello_world can not work! it is very strange !!!!!!!!![/b] --- Quote End --- It is because the file size of them. What type of dowload cable do you use? I find Byteblaster II will occur similar errors. Please refe to:run as hardware error (http://www.niosforum.com/forum/index.php?act=st&f=2&t=2099)- Mark as New
yes ,I use byteblasterII!
but when I use quartusII4.1 and niosII1.0, everything is ok! is there a bug in niosII 5.0?
