about memory map
At the time of Nios, there were files such as ***.nm.
But in Nios2, a similar file isn't generated.
Will the file that NiosII substitutes for ***.nm not be generated?
Hi suyo,
You can generate an address map using nios2-elf-nm.
Use the -n option to sort by address.
--Scott
Hi Sccot,
Thank you quick responce.
I could solve a problem in your way.
I owe you gratitude.
Thank you very much.
suyo
