12746 Discussions
about sdram addrss/data bus shared
hi all:
In tne altera reference design, the SDRAM not share address/data bus with flash,
sram, lan chip. But in my design I shared sdaram address/data bus with flash to
reduce IO pins. Now I meet a problem. I can run the single program fine without
OS.But when I run uClinux 2.6 os on own board the system will boot fail.The fail
information is CRC erro. However I run the same uClinux 2.6 os on altera cyclone
1c20 dev board, it is work fine.The difference is my design shared the SDRAM a/d
bus with flash.I think maybe the reason is disturb.
Who can give me some advice to solve the question?
Thank a lot!
So you program sof and kernel to flash, then try to boot without jtag debug/terminal?
Please give more error message.
--- Quote Start ---
originally posted by hippo@Apr 10 2006, 10:39 PM
so you program sof and kernel to flash, then try to boot without jtag debug/terminal?
please give more error message.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14218)
--- quote end ---
--- Quote End ---
hi hippo:
Can I program sof in the epcs and program zImage in the flash?
Sounds like you have hardware issues. If you have SDRAM and Flash on the same bus (which is a bad idea IMO), the SDRAM bus will be more heavily loaded, meaning you should test it for stability first.
- You should run the SDRAM at full speed with a hardware core to verify for errors
- Have you downloaded just to SDRAM and run from RAM instead of Flash?
- If you can, disable or remove the Flash chip and just run from SDRAM. This should help you narrow down the problem.
--- Quote Start ---
originally posted by jdhar@Apr 11 2006, 02:04 AM
sounds like you have hardware issues. if you have sdram and flash on the same bus (which is a bad idea imo), the sdram bus will be more heavily loaded, meaning you should test it for stability first.
- you should run the sdram at full speed with a hardware core to verify for errors
- have you downloaded just to sdram and run from ram instead of flash?
- if you can, disable or remove the flash chip and just run from sdram. this should help you narrow down the problem.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14231)
--- quote end ---
--- Quote End ---
Thank you for reply.
I just downloaded zImage to sdram use "nios2-download -g zImage" command.
--- Quote Start ---
originally posted by alex824+apr 11 2006, 01:59 am--><div class='quotetop'>quote (alex824 @ apr 11 2006, 01:59 am)</div>
--- quote start ---
<!--quotebegin-hippo@Apr 10 2006, 10:39 PM
--- quote end ---
--- Quote End ---
hi hippo:
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14230)</div>
[/b]
--- Quote End ---
sorry. The question of my is wrong.
The correct question is: Can I program pof in the epcs flash and program zImage in the cfi flash?
TO_BE_DONE
[<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14247)</div>
--- Quote End ---
sure,
setup nios2 to reset from cfi flash in sopc builder, and generate.
setup your fpga to configure from AS, epcs in quartusII and compile . the config mode pins of fpga should be wired to epcs (standard or fast) config mode .
then you can program the sof to epcs, and zImage to cfi flash, as in step7 in the buildroot guide,
# Creating .flash file for the FPGA configuration sof2flash --epcs --input=your_system.sof --output=standard.flash# Programming flash with the FPGA configuration nios2-flash-programmer --epcs --base=0x02200000 standard.flash# Creating .flash file for the project elf2flash --base=0x00000000 --end=0xffffff --reset=0x0 --input=zImage --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec# Programming flash with the project nios2-flash-programmer --base=0x00000000 ext_flash.flash
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14251)</div>
--- Quote End ---
hi hippo:
Thank you for you reply.But I still have some doubt.
If I use quartus programer burn the cpu.pof in to EPCS4 using AS mode by jtag download cable.Do I need exec following step?
Because the nios2 cpu.pof have already exist the EPCS4.When I pown on the
customer board , the FPGA will download the cpu.pof from the EPCS4 ,then the
nios2 cpu will reset from the cfi flash address 0x00000000.
--- Quote Start ---
--- Quote End ---
sure,
--- Quote End ---
hi hippo:
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14264)</div>
--- Quote End ---
The two methods do the same thing.
So you can just use quartusII programmer for pof.
there is no need to use sof2flash again.
