when i used sdram as the exception address with the flash,the IDE told me following messages:
"Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused" as log as i run as the nios hardware. How did it happen? And i also met such question: "**** Incremental build of configuration Debug for project hello_world_1 **** make -s all Creating generated_app.mk... WARNING: Default charset GBK not supported, using ISO-8859-1 instead Creating system.h... Jul 2, 2005 7:50:42 PM - (??) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NumberFormatException: Negative sign in wrong position WARNING: Default charset GBK not supported, using ISO-8859-1 instead make[1]: *** [system_description/../obj/system.h-t] Error 1 make: *** [system_project] Error 2 Anybody can help me? thanks a lot!!Link Copied
