access the custom logic
FOr nios I
I have created a custome logic pwm for my project...SOPC assignes me address of 4A0 - 4AF
address 00 - duty cycle
address 01 - clock divide
is it correct is program it in C such this way ?
int *duty_cycle = (int *) 0x000004A0; //
int *clock_divide = (int *) 0x000004A4; //
int w = 10;
int z = 1000;
//assigned value to the inputs.
*clock_divide = z;
*duty_cycle = w;
i have tried this but htere is no output...any suggestions ?
You should better consider using the IORD() and IOWR() macros from the <io.h> for accessing your IP registers, or you might experience arratic behaviours due to data cache operations and compiler optimizations.
If you have tested your component outside of the NIOS-II system (in a simulation only separate project) and the results were as expected, and you&#39;re still having problems, you could "signaltap" your entire design.
