alt_timestamp_start?
I was trying to use the Hi-Res Timer, but NIOS II IDE Version 1.1.0 gave me the following error
"Error undefined reference to `alt_timestamp_start' hello_world.c hello_world_0 line 24"
for the following simple code:
# include <stdio.h># include <alt_types.h># include "sys/alt_timestamp.h"
int main()
printf("Hello from Nios II!\n");
alt_timestamp_start(); // Tried to use Hi-Res Timer
return 0;
The example "Dhrystone" did work.
Thanks for any suggestions.
Is this error happening at the linking stage?
If so then the problem may be that you haven&#39;t selected a timestamp timer. Please look at the system library properties page and check that you have selected a hardware device for both timers.
Yes, I learned that I had to right click on the project and bring up the "system Library Properties" page and enable "high res timer" there.
Thanks!
