altera 11 usbblaster ubuntu 11.04
名誉分销商 II
2,462 次查看
Hello all,
I am running into the dreaded ubuntu usbblaster issue. I am on ubuntu 11.04 32 bits with Altera 11 (which is supposed to be better). I got this to work using altera 10 with earlier ubuntu, but no cigar with the current permutation. Any hints on how one might fault isolate this issue are appreciated.
$ jtagconfig
1) USB-Blaster [2-4]
020F30DD
And nios2-download always gives this error.
"There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary."
I do repeated download a new SOF file with the reference design from altera (and that completes w/o errors), and also use the power up reset reference design w/o any success.
I have this in my /etc/udev/rules.d/40-altera-usbblaster.rules (I tried some the other variations being passed around on the web and they dont appear to work complaining that there isn't sufficient privilege to access the port)
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster", GROUP="plugdev"
$ ls -l /dev/usbblaster
lrwxrwxrwx 1 root root 15 2011-09-26 15:24 /dev/usbblaster -> bus/usb/002/009
$ ls -l /dev/bus/usb/002/009
crw-rw-r-- 1 root plugdev 189, 136 2011-09-26 15:35 /dev/bus/usb/002/009
$ lsusb -d 09fb:6001 -v
Bus 002 Device 009: ID 09fb:6001 Altera
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x09fb Altera
idProduct 0x6001
bcdDevice 4.00
iManufacturer 1 Altera
iProduct 2 USB-Blaster
iSerial 3 91d28408
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 150mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 USB-Blaster
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
0 项奖励
6 回复数
名誉分销商 II
705 次查看
So in summary, I can program the device with the reference design, but somehow I am unable to download software.
$ nios2-configure-sof niosii_ethernet_standard_3c25.sof
Searching for SOF file:
in .
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag -o p;./niosii_ethernet_standard_3c25.sof
Info: Using programming cable "USB-Blaster [2-4]"
Info: Using programming file ./niosii_ethernet_standard_3c25.sof with checksum 0x00CC2B53 for device EP3C25F324@1
Info: Started Programmer operation at Mon Sep 26 16:28:37 2011
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020F30DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Mon Sep 26 16:28:38 2011
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 94 megabytes
Info: Processing ended: Mon Sep 26 16:28:38 2011
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:00
$ make
Info: Building ../../bsp/hal_default/
make --no-print-directory -C ../../bsp/hal_default/
[BSP build complete]
[hello_world build complete]
$ nios2-download hello_world.elf
0 项奖励
名誉分销商 II
705 次查看
I did try some of the other solutions suggested on this forum
$ cat /etc/udev/rules.d/40-altera-usbblaster.rules
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
$ sudo udevadm control --reload-rules
$ jtagconfig
020F30DD
$ /home/hill/altera/11.0/nios2eds/nios2_command_shell.sh
Altera Nios2 Command Shell [GCC 4]
Version 11.0, Build 157
$ jtagconfig
020F30DD
0 项奖励
名誉分销商 II
705 次查看
OK, found the solution (on the wiki)!
$ sudo mkdir /etc/jtagd
$ sudo cp /home/hill/altera/11.0/quartus/linux/pgm_parts.txt /etc/jtagd/jtagd.pgm_parts
$ ls /etc/jtagd
jtagd.pgm_parts
$ jtagconfig
020F30DD
$ killall jtagd
$ jtagd
$ jtagconfig
020F30DD EP3C25/EP4CE22
Using cable "USB-Blaster [2-4]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 49KB in 2.7s (18.1KB/s)
Verified OK
Leaving target processor paused
success!
0 项奖励
名誉分销商 II
705 次查看
Thanks for posting your results..
0 项奖励
名誉分销商 II
705 次查看
Just wanted to say thanks to JeffreyOHill as well. His solution worked for me. Much appreciated.
0 项奖励
名誉分销商 II
705 次查看
For what it's worth, this also worked for me on machine where I just did a fresh install of Ubuntu 12.04 (not an update).
JefferyOHill, thanks for such a comprehensive report. May you live to be a thousand years old.
0 项奖励
回复
