assemble under nios2
Hi all,
i write a program under nios2 using assemble lanauge, following is the source code
# include <linux/module.h># include <linux/kernel.h>
void print(void)
printk("function print\n");
typedef void(*pointer)(void);
ulong code[3];
void jump(void)
__asm__("movia r12, print");
__asm__("jmp r12");
int __init init_filter(void)
jump();
void __exit exit_filter(void)
module_init(init_filter);
module_exit(exit_filter);
this can work well, but if i change the function init_filter as bellow, the system will reboot,
pointer p;
code[0]=0x03000034;
code[1]=0x63000004;
code[2]=0x6000683a;
p = (pointer)code;
p();
code[0]~code[2] is the hex value that i get from nios2-elf-objdump according to two assemble sentences.
how should i do?
thanks a lot
Hi qiunuoku,
I&#39;m assuming that &#39;code&#39; is a valid pointer ... and the opcodes are correct. That said, if you&#39;re
using a data cache, you need to flush the region you modified with the new instructions.
Then if you&#39;re using and instruction cache, you need invalidate the appropiate region as well.
Otherwise, you will likely be executing stale bits rather than your copied code.
--Scott
to Scott
thanks
