basics on jffs2
I would like to use jffs2 with ecos on the cycloneII NIOSII development board.
I have included jffs2 into the ecos lib.
Now I don't know what to do next - I have looked for some documentation but could not find it in the ecos directories.
Any help on getting started would be great.
You can find example code that uses jffs2 in the tests directory of the jffs2 package. Limited documentation, and links to the jffs2 mailing lists, can be found here (http://sources.redhat.com/jffs2/).
Hi pxs,
1. create a jffs2 filesystem
You can create a filesystem image with mkfs.jffs2 and download it to your jffs2 partition.
As an alternative, you can simply erase your jffs2 partition.
2. mount the partition
You can mount the partition in cycuser_start(). For example:
void cyg_user_start(void) { ... # ifdef CYGPKG_IO_FILEIO     if (mount ("/dev/flash1", "/", "jffs2") == 0)  chdir ("/");# endif ... }
3. use the standard routines
For example:ret = mkdir ("newdir", S_IRWXU|S_IRWXG|S_IRWXO); /* Create a directory */ ret = rmdir ("olddir"); /* Remove a directory */ ret = rename ("oldname", "newname"); /* Rename a file */ /* ... and so on ... */
Hope this is helpful.
--Scott
The only time I used mkfs.jffs2 was on an uClinux box and it had mkfs.jffs2 on it. So I created the directory structure in RAM and then ran mkfs.jffs2 on the uClinux box and it created the image. I then used erase and copied the image over.
Then I used mount.
Can you explain how you create the image in more detail? Do you use a Linux box to create it or do you download the source and compile it on a windows box using cygwin, or do you compile it in NIOS?
How do I download it to the jffs2 partition? How do I create the jffs2 partition?
Do I need Redboot?
Hi pxs,
1. In your unix environment create a directory that will serve as the root of your jffs2 filesystem.
2. Then populate this directory with all of the directories, files, links, etc. that are needed for your target system.
3. Run mkfs.jffs2, specifying the directory you created in step 1 (the -r, -d, or --root option).
You'll need to specify the eraseblock size also. A single 8-bit device with 64K sector size would be
"-e 0x10000", two of them in parallel would be "-e 0x20000" and so on. It's also a good idea to explicitly
set the endian order in your makefiles as a precaution, use -l option for nios. By default mkfs.jffs2 will
use the endian order of the machine you run it on (for nios and x86 this is never a problem since
they're both little endian -- but PowerPC hosts can cause issues). So an invocation of mkfs.jffs2
might look something like this if your file structure is in the directory "ecos_root":
$ mkfs.jffs2 -d ecos_root -e 0x10000 -o jffs2.bin -l
4. Once you have the binary, you can use bin2flash and the nios2-flash-programmer to load
the binary into your jffs2 partition on your target board.
I always use mkfs.jffs2 on a unix box. Under cygwin, you'll loose some of your file attributes (like
the execute bits or example) which can be troublesome for embedded linux targets. But for ecos,
you may not really care.
Prior to Nios II 5.0, the Microtronix uClinux linux came with host gcc ... and the mkfs.jffs2 source code
available at: http://www.psyent.com/download (http://www.psyent.com/download) would build cleanly in an SDK shell windown. I haven't
tried these sources with the latest 5.0 stuff yet. I know there are problems building this code in a
"normal" cygwin environment from www.cygwin.com.
--Scott
Hi pxs,
Just FYI ...
> I haven't tried these sources with the latest 5.0 stuff yet.
I was able to finish installing the Microtronix linux uClinux for Nios II 5.0, and the psyent
sources for mkfs.jffs2, mkcramfs, etc. build just fine in the Nios SDK shell environment ... they also
build fine under RH9.
--Scott
Thanks Scott,
I have downloaded Microtronix linux uClinux for Nios II 5.0 and compiled mkfs.jffs2 without a problem.
I created a few directories and a file and then I used the following command to generated jffs2.img
$>  mkfs.jffs2 -d jffs2 -e 0x10000 -o jffs2.img -l
then
$>  bin2flash --input=jffs2.img  --base=0x0000 0000 --location=0x0060 0000 --verbose
I used the base=0x0000 0000 because I am using the Altera NIOS CYCLONE II Development Board.
I used the location at 0x0060 0000 because this is in the user region (as per Nios development brd cycloneII Edition Ref. Manual).
User region= 0x0000 0000 to 0x00BF FFFF
I placed it high in the user region but I am not sure where ecos is placed - do you know where I can find this information?
The previous command gives a output of jffs2.flash
I then tried to download jffs2.flash to the board with the following command without succuss.
$>  nios2-flash-programmer --base=0x0000 0000 --input=jffs2.flash --location=0x0060 0000 --verbose --sof=/cygdrive/c/altera/kits/nios2/examples/verilog/niosII_cycloneII_2c35/standard/standard.sof
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Aug 16, 2005 4:31:49 PM - (FINE) nios2-flash-programmer: nios2-flash-programmer starting
Aug 16, 2005 4:31:49 PM - (INFO) nios2-flash-programmer: args = --base=0x00000000 --input=jffs2.flash --verbose --sof=standard.sof
Aug 16, 2005 4:31:49 PM - (INFO) nios2-flash-programmer: Attempting to read input-data from c:jffs2.flash
Aug 16, 2005 4:31:49 PM - (INFO) nios2-flash-programmer: Launching Quartus Programmer to download:
  standard.sof
Aug 16, 2005 4:31:49 PM - (FINE) nios2-flash-programmer: Quartus Pgm launched
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag --operation=p;standard.sof
Info: Using programming cable "USB-Blaster [USB-0]"
Info: Started Programmer operation at Tue Aug 16 16:31:51 2005
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020B40DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Tue Aug 16 16:31:53 2005
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
    Info: Processing ended: Tue Aug 16 16:31:53 2005
    Info: Elapsed time: 00:00:04
Aug 16, 2005 4:31:53 PM - (FINE) nios2-flash-programmer: SOF programming done. exit code = 0x0000
Connecting with target design
Attempting to resynch with target
Unable to synchronize with target.
Aug 16, 2005 4:31:56 PM - (SEVERE) nios2-flash-programmer: Error opening target hardware
  In order to program flash, you must first create a purpose-built
  flash-programming design (i.e. FPGA configuration) and associate it with
  your particular board.  The Nios development kit is delivered with purpose-built
  flash-programming designs pre-built for several development boards.  If you wish
  to program flash on your own board, you must first create a flash-programming
  design.
  The process of creating a flash-programming design for your board is mostly
  automated.  From a bash-shell, execute this script:
        mk_target_board --help
  The help-message includes references to other documentation on programming
  flash and targeting Nios systems to custom board designs.
- exiting.[/b]
--- Quote End ---
I am using a pre-built configuration (cycloneII 2c35) so I am not sure why it wants me to use mk_target_board
Any ideas?
Can you explain further about how to make the jffs2 partition you spoke of previously (see below). Is this the jffs2.img (jffs2.flash) or do I have to do something to make the partition?
--- Quote Start ---
1. Create a jffs2 filesystem
As an alternative, you can simply erase your jffs2 partition.[/b]
--- Quote End ---
Hi pxs,
ecos is normally stored at the reset address ... so it will start at power-on or cpu reset. You can check your
elf file with objdump:
$ nios2-elf-objdump -h your-ecos-elf-file
--- Quote Start ---
--sof=/cygdrive/c/altera/kits/nios2/examples/verilog/niosii_cycloneii_2c35/standard/standard.sof[/b]
--- Quote End ---
You need to specify the _programmer_ sof for the board ... not the example configuration. Use the sof in:
$SOPC_KIT_NIOS2/components/altera_nios_dev_board_cyclone_2c35/system/altera_nios_dev_board_cyclone_2c35.sof
You can divide your flash into several "blocks" or "areas" that can be independently managed by jffs2 ... all in
the same spirit as partitions on a hard disk drive. So from a software point-of-view, it appears as though you
have multiple flash "drives".
Since I&#39;m primarily a linux person, I&#39;ve never used more than a single partition with ecos ... but I&#39;m assuming
there&#39;s an easy way to create more than one with the config tool. Maybe monkeyboy can help with this.
Regardless, you can configure your default partition in the "Flash device drivers" configuration under
"instantiate in I/O block device API" -> "static configuration".
--Scott
