boa and cgi-bin
AN3238 User Interface Design using CGI Programming and Boa Web server
http://www.freescale.com/files/32bit/doc/app_note/an3238.pdf (http://www.freescale.com/files/32bit/doc/app_note/an3238.pdf
cd ~/uClinux-dist-test
make menuconfig
Miscellaneous Configuration ---> [*] generic cgi
Source in,
~/uClinux-dist-test/user/cgi_generic
~/uClinux-dist-test/vendors/Generic/httpd
Hi hippo.
Thank you very much.
Could you see the "is the zImage right".
Thank you..
