If I build a "C" application and run it in the sbin directory it works. If the application is also installed in the root directory for boa (var/www) when the application run it is killed with the following message like:
reloc outside program 0x27840 (0-0x66cc/0x4130), killing TestCCGI_rev3.c files are named TestCCGI_rev3.cgi.exe Does anyone have any ideas?Link Copied
--- Quote Start --- originally posted by golf@Oct 28 2005, 04:56 PM does anyone have any ideas? --- Quote End --- I would guess that something is wrong with your cgi program and not with boa. I've been running Boa for months without any problems (running a cgi program). Maybe you should start debugging your cgi program on a more stable platform than Nios II (one with MMU).
