12748 Discussions
booting uclinux from u-boot
hi all
I am trying to boot uclinux from u-boot on 2s60 board.
I have one doubt regarding Exception vector table entry point address.
What I have observed in uclinux (head.S) that exception vector table entry point jump instruction sits at Base Addr of RAM + 0x20 offset, same information I have given in Hardware configuration file in sopc builder (.sof).
And same location is used for u-boot's Execption vector table (specified in the u-boot config file).
My SDRAM start address is 0x0100_0000.
So exception vector table sits at 0x0100_0020 in both the cases of u-boot and uclinux.
The kernel image has entry_address at 0x0100_0000.
Now if I download kernel image through u-boot, then Exception table gets overwritten by kernel image and u-boot hangs.
Please share your experience with how you deal with this issue. I mean when you boot kernel from u-boot then which address is given for exception vector table. Or it's ok to use same addr there is some other issue ?
thanks
Ankur
--- Quote Start ---
originally posted by ankur@May 29 2006, 04:24 AM
hi all
i am trying to boot uclinux from u-boot on 2s60 board.
i have one doubt regarding exception vector table entry point address.
what i have observed in uclinux (head.s) that exception vector table entry point jump instruction sits at base addr of ram + 0x20 offset, same information i have given in hardware configuration file in sopc builder (.sof).
and same location is used for u-boot's execption vector table (specified in the u-boot config file).
my sdram start address is 0x0100_0000.
so exception vector table sits at 0x0100_0020 in both the cases of u-boot and uclinux.
the kernel image has entry_address at 0x0100_0000.
now if i download kernel image through u-boot, then exception table gets overwritten by kernel image and u-boot hangs.
please share your experience with how you deal with this issue. i mean when you boot kernel from u-boot then which address is given for exception vector table. or it's ok to use same addr there is some other issue ?
thanks
ankur
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15652)
--- quote end ---
--- Quote End ---
hi all,
I can download my kernel image file in the sdram. There were some misunderstanding with CFG_NIOS_CPU_VEC_BASE and CFG_EXCEPTION_ADDR.
Now both I made equal to 0x0100_0020.
But still I can&#39;t boot my kernel.
I am downloading uncompressed kernel through tftpboot at 0x0100_0000.
Then I give bootm 0x0100_0000
Is it fine or should I change the location ??
thanks
Ankur
--- Quote Start ---
originally posted by ankur+may 29 2006, 08:18 am--><div class='quotetop'>quote (ankur @ may 29 2006, 08:18 am)</div>
--- quote start ---
<!--quotebegin-ankur@May 29 2006, 04:24 AM
hi all
and same location is used for u-boot&#39;s execption vector table (specified in the u-boot config file).
please share your experience with how you deal with this issue. i mean when you boot kernel from u-boot then which address is given for exception vector table. or it&#39;s ok to use same addr there is some other issue ?
thanks
ankur
--- quote end ---
--- Quote End ---
hi all,
thanks
Ankur
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15664)</div>
[/b]
--- Quote End ---
Hi Ankur,
> CFG_EXCEPTION_ADDR.
First, don&#39;t use CFG_NIOS_CPU_VEC_BASE ... this is an old (and totally brain-damaged) obfuscation
that was foolishly added to some Nios-32 u-boot board configurations -- it is not used in the
Nios II sources. And please don&#39;t ask for any details about CFG_NIOS_CPU_VEC_BASE
-- I&#39;ll just end up embarrassing myself with an endless rant ;-)
Second, please use the code from: http://www.psyent.com/download (http://www.psyent.com/download) -- it contains all of the patches
that have been submitted to the u-boot project (and are still pending). If you&#39;re using code directly
from the u-boot project you will likely have problems without the patches.
Change this -- you are overwriting your exception trampoline during download. The first
interrupt will put the CPU in the weeds. Load the image somewhere higher in memory.
The &#39;bootm&#39; command will copy (and optionally decompress) the image to the load
address you specified with mkimage, after disabling interrupts. Try downloading to
0140_0000 for example (but leave the load address and entry point at 0100_0000). Then,
==> bootm 1400000
--Scott
--- Quote Start ---
originally posted by smcnutt@May 30 2006, 07:39 PM
hi ankur,
> there were some misunderstanding with cfg_nios_cpu_vec_base and
> cfg_exception_addr.
> now both i made equal to 0x0100_0020.
first, don&#39;t use cfg_nios_cpu_vec_base ... this is an old (and totally brain-damaged) obfuscation
that was foolishly added to some nios-32 u-boot board configurations -- it is not used in the
nios ii sources. and please don&#39;t ask for any details about cfg_nios_cpu_vec_base
-- i&#39;ll just end up embarrassing myself with an endless rant ;-)
second, please use the code from: http://www.psyent.com/download (http://www.psyent.com/download) -- it contains all of the patches
that have been submitted to the u-boot project (and are still pending). if you&#39;re using code directly
> then i give bootm 0x0100_0000
> is it fine or should i change the location ??
change this -- you are overwriting your exception trampoline during download. the first
interrupt will put the cpu in the weeds. load the image somewhere higher in memory.
the &#39;bootm&#39; command will copy (and optionally decompress) the image to the load
address you specified with mkimage, after disabling interrupts.[/b] Try downloading to
==> bootm 1400000
--Scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15700)
--- Quote End ---
[/b]
--- Quote End ---
hi Scott,
thanks, for the reply. Actually I was using u-boot -1.1.2 taken from source forge. (I know its old now). But after following your instructions uclinux is booting now.
thanks once again
Ankur
