12748 Discussions
build Toolchain error! who can help me?
I built the toolchain in Fedora12 following
http://www.nioswiki.com/installnios2linux
but , I got this error message:
gcc: c-parse.c: no such file or directory
gcc: no input files
make[2]: *** [c-parse.o] error 1
make[2]: leaving directory `/nios2-linux/toolchain-build/build/gcc-bootstrap-build/gcc'
make[1]: *** [all-gcc] error 2
make[1]: leaving directory `/nios2-linux/toolchain-build/build/gcc-bootstrap-build'
make: *** [/nios2-linux/toolchain-build/bui
now please tell me that what i have to do to prevent this error.
the file is exist:
[root@f12 ~]# locate c-parse.c
/nios2-linux/gcc3/gcc/c-parse.c
/nios2-linux/gcc3/gcc/objc/objc-parse.c
[root@f12 ~]#
who can tell me how to solve it ?
thanks
We had the same problem. It can be solved by modifying file nios2-linux/gcc3/gcc/c-parse.y. From the line 1650, 1661, 1670 and 1675 modify $$ to $<ttype>$. For example change the line 1650 from { $$ = start_struct (RECORD_TYPE, $2); to { $<ttype>$ = start_struct (RECORD_TYPE, $2);
Thanks!
I can't imagine how you figured that out.
--- Quote Start ---
--- Quote End ---
He yacc'ed :-) Or grokked YACC.
I have much to learn!
--- Quote Start ---
--- Quote End ---
you are god!
