12748 Discussions
building problem - toolchain
Your kernel directory 'linux-2.6.x' lacks a vmImage file:
/home/z125188/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/vmImage
This usually means your toolchain lacks u-boot tools. Please check your
toolchain installation. The file is generated when running 'make linux'.
how do i check my toolchain installation? :/
In normal nios2nommu build, mkimage is not needed. You should use "make" once to build everything.
Only if you are using "trunk" branch of uClinux-dist, it will need mkimage. mkimage is available from u-boot, you can either install it or build it.
1. for ubuntu/debian, apt-get install uboot-mkimage
2. cd nios2-linux/toolchain-build
make u-boot
# then move the mkimage to your toolchain binary dir in your PATH.
- Hippo
<div class='quotetop'>QUOTE (hippo @ Aug 24 2009, 08:17 PM) <{post_snapback}> (index.php?act=findpost&pid=23567)</div>
--- Quote Start ---
make u-boot[/b]
--- Quote End ---
Those steps worked fine but i still get the same error.
I want to try nios2 with MMU
without it worked fine and i build a lot of zImages but the MMU stuffs not working.
do i have to move the "mkimage" binary or just add the path to the PATH variable?
i tried adding it with PATH=$PATH:/home/xyz/nios2-linux/toolchain-build/u-boot/tools
mfg Sven
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
WARNING: modpost: Found 4 section mismatch(es).
To see full details build your kernel with:
&#39;make CONFIG_DEBUG_SECTION_MISMATCH=y&#39;
GEN .version
CHK include/linux/compile.h
UPD include/linux/compile.h
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
KSYM .tmp_kallsyms1.S
AS .tmp_kallsyms1.o
LD .tmp_vmlinux2
KSYM .tmp_kallsyms2.S
AS .tmp_kallsyms2.o
LD vmlinux
SYSMAP System.map
SYSMAP .tmp_System.map
OBJCOPY arch/nios2/boot/vmlinux.bin
GZIP arch/nios2/boot/vmlinux.gz
UIMAGE arch/nios2/boot/vmImage
/usr/bin/mkimage [OPTIONS]
Options:
-f <MD5 name> Specify an input MD5 file. MD5s must be in jigdo&#39;s
pseudo-base64 format
-j <jigdo name> Specify the input jigdo file
-t <template name> Specify the input template file
-m <item=path> Map <item> to <path> to find the files in the mirror
-M <missing name> Rather than try to build the image, just check that
all the needed files are available. If any are missing,
list them in this file.
-v Make the output logging more verbose
-l <logfile> Specify a logfile to append to.
If not specified, will log to stderr
-o <outfile> Specify a file to write the ISO image to.
If not specified, will write to stdout
-q Quick mode. Don&#39;t check MD5sums. Dangerous!
-s <bytenum> Start byte number; will start at 0 if not specified
-e <bytenum> End byte number; will end at EOF if not specified
-z Don&#39;t attempt to rebuild the image; simply print its
size in bytes
Kernel: arch/nios2/boot/vmImage is ready
Building modules, stage 2.
MODPOST 0 modules
make[1]: Verlasse Verzeichnis &#39;/home/z125188/nios2-linux/linux-2.6&#39;
if [ -f linux-2.6.x/vmlinux ]; then
ln -f linux-2.6.x/vmlinux linux-2.6.x/linux ;
fi[/b]
--- Quote End ---
why is he telling me the vmImage is ready when there is none ? :/
<div class='quotetop'>QUOTE (SvenHe @ Aug 25 2009, 04:15 PM) <{post_snapback}> (index.php?act=findpost&pid=23585)</div>
--- Quote Start ---
I want to try nios2 with MMU[/b]
--- Quote End ---
The nios2 linux with MMU is under final testing and will be opened for the public soon. Please wait.
- Hippo
I don't want to update this message. But it seems to me that it is related to my issue. After i compiled the kernel, I got this message.
Image Name: Linux-3.7.0-01377-g1061bd7
Created: Mon Mar 25 15:41:30 2013
Image Type: NIOS II Linux Kernel Image (gzip compressed)
Data Size: 1445018 Bytes = 1411.15 kB = 1.38 MB
Load Address: c8000000
Entry Point: c8000000
Configuring .sof files works smoothly but i could not download vmImage file:
rootF15: /path/nios2-download vmImage
nios2-elf-objcopy:./vmImage: File format not recognized
./vmImage.srec: Unable to open input file
rm: cannot remove `./vmImage.srec': No such file or directory
Have anybody encountered with this problem ? How to obtain zImage ?
