buildroot fialed!Help!
Hi ,I follow Hippo 's instructions to build the buildroot. But it failed.
The sourece codes i use are:
buildroot-20060506.tar.bz2,busybox-20060506.tar.bz2,
uClibc-20060506.tar.bz2,uClinux-20060506.tar.bz2,build0411.zip.
I edit SNAPSHOT of build like this: SNAPSHOT=20060506.
When build, there are errors.
I donot know where to download the latest version of build file(such as build0411.zip).The link(http://forum.niosforum.com/forum/index.php?showtopic=3787) puzzled me.
thanks in advance.
--- Quote Start ---
originally posted by xunios@May 7 2006, 09:40 PM
hi ,i follow hippo 's instructions to build the buildroot. but it failed.
the sourece codes i use are:
uclibc-20060506.tar.bz2,uclinux-20060506.tar.bz2,build0411.zip.
i edit snapshot of  build like this: snapshot=20060506.
when build, there are errors.
i donot know where to download the latest version of build file(such as build0411.zip).the link(http://forum.niosforum.com/forum/index.php?showtopic=3787) puzzled me.
thanks in advance.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15146)
--- quote end ---
--- Quote End ---
Please give the last 30 lines of your build message.
TO_BE_DONE
it seems lack some packages for config.
You must select "developement packages" during installation of FC4/5.
--- Quote Start ---
you must select "developement packages" during installation of fc4/5.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15162)
--- quote end ---
--- Quote End ---
make menuconfig passed,,but failed in make.(after makemenuconfig,the /buildroot/build_nios2/busybox/ doesnot exist.)
Here hte errors after make:
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: &#22312;&#20989; &#25968; ‘md_convert_frag’ &#20013;&#65306;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1338: &#35686;&#21578;&#65306;&#21021;&#22987;&#21270;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1356: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1357: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1358: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1376: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_chars_to_number’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1405: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1406: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1407: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1408: &#35686;&#21578;&#65306;&#20256;&#36882;&#21442;&#25968; 1 (&#23646;&#20110; ‘md_number_to_chars’) &#32473;&#25351;&#38024;&#26102;&#30446;&#26631;&#19982;&#25351;&#38024;&#26377;/&#26080;&#31526;&#21495;&#19981;&#19968;&#33268;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: &#22312;&#20989; &#25968; ‘md_apply_fix3’ &#20013;&#65306;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1664: &#38169;&#35823;&#65306;&#36171;&#20540;&#36816;&#31639;&#20013;&#30340;&#24038;&#20540;&#26080;&#25928;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: &#22312;&#20989; &#25968; ‘nios2_check_overflow’ &#20013;&#65306;
/root/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1709: &#38169;&#35823;&#65306;&#36171;&#20540;&#36816;&#31639;&#20013;&#30340;&#24038;&#20540;&#26080;&#25928;
make[4]: *** [tc-nios2.o] &#38169;&#35823; 1
make[4]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build/gas&#39;
make[3]: *** [all-recursive] &#38169;&#35823; 1
make[3]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build/gas&#39;
make[2]: *** [all] &#38169;&#35823; 2
make[2]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build/gas&#39;
make[1]: *** [all-gas] &#38169;&#35823; 2
make[1]: Leaving directory `/root/buildroot/toolchain_build_nios2/binutils-2.15-build&#39;
make: *** [/root/buildroot/toolchain_build_nios2/binutils-2.15-build/binutils/objdump] &#38169;&#35823; 2
--- Quote Start ---
originally posted by xunios+may 9 2006, 09:38 am--><div class='quotetop'>quote (xunios @ may 9 2006, 09:38 am)</div>
--- quote start ---
<!--quotebegin-hippo@May 7 2006, 08:11 PM
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15205)</div>
[/b]
--- Quote End ---
Did you install gcc-32 as I said in the buildroot guide?
Check with "gcc -v" .
The gcc4 can not compile binutils-2.15 .
Please check the binary tools on Jhdar&#39;s site, (thanks a lot to his help)
http://via.fps-tech.org/snapshots/nios2/ (http://via.fps-tech.org/snapshots/nios2/)
