12748 Discussions
built program in nios2 IDE 5.0
Hi all:
I make ncurses 5.5 and cdk source code by RED HAT LINUX 8.0. After make I got
the include files and the interrelated libcdk.a , libncurses.a .Then I edit my
application program use Microtronix Nios II LINUX Application Project module in
nios2 IDE 5.0. My source code as follows:
# include "cdkscreen.h"
int main(void)
initCDKColor();
return 0;
My makefile as follows:
# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 1
PROJ_NAME = testcdkc
LIBNETDIR := cdk_lib
INSTALL_DIR =
PROGS := $(PROJ_NAME).exe
CFLAGS +=
# # You should not need to modify anything beyond this point#
include Rules.mak
ifeq '$(DEBUG)' '1'
PROGS += $(PROGS:.exe=.gdb)
endif
CFLAGS += -I include -I ncurses_include -I$(LIBNETDIR)
LDLIBS += $(LIBNETDIR)/libncurses.a $(LIBNETDIR)/libcdk.a
all: $(PROGS)
.PHONY: clean
clean:
-rm -f *.[oad] *.elf *.gdb *.bin *.exe
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
But I build the program fail. The fail information as follows:
make -k all
no emulation specific options.
nios2-elf-gcc -nostdinc -D__linux__ -O0 -g -I"d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -I include -I ncurses_include -Icdk_lib -Wall -c -o testcdkc.o testcdkc.c
nios2-elf-gcc -msys-crt0="d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/crt0.o -r -d -L"d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib -o testcdkc.bin testcdkc.o /cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a "d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/lib/libc.a cdk_lib/libncurses.a cdk_lib/libcdk.a cdk_lib/libnet.a
/cygdrive/d/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: cdk_lib/libcdk.a(draw.o): Relocations in generic ELF (EM: 3)
cdk_lib/libcdk.a: could not read symbols: File in wrong format
collect2: ld returned 1 exit status
make: *** [testcdkc.bin] Error 1
make: Target `all' not remade because of errors.
rm testcdkc.o
I think the reason of my failure is
Who can tell me resolvent? I think it cause to libcdk.a through RAD HAT LINUCX turn into, it is fail to compile to lead to the fact.
Thanks a lot
up
--- Quote Start ---
originally posted by alex824@Nov 10 2005, 09:50 PM
hi all:
i make ncurses 5.5 and cdk source code by red hat linux 8.0. after make i got
the include files and  the interrelated libcdk.a , libncurses.a .then i edit my
application program use microtronix nios ii linux application project module in
nios2 ide 5.0.
--- Quote End ---
It looks like you compiled i386(intel) binaries with your RedHat machine. You need to crosscompile ncurses for the nios2 platform in order to use the libraries on your nios2 system. The fact that you get:
"could not read symbols: File in wrong format"
Is most likely because it's a i386 lib and not a nios2 lib.
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10966)</div>
--- Quote End ---
Hi wqossens, thanks for you reply. I think you are right.
But I dont&#39;t know how to rework the ncurses configure file.
In the nios sdk shell, I type ./configure to crosscompile ncurses.
but fail. The error information as follow:
egrep: not found
egrep: not found
egrep: not found
Configuring NCURSES . ABI <Tue Nov 15 10:18:48 2005>
configure: error: Release major-version value is empty
What can I do?Should I must use microtronix Nios II Cross Development Kit to
crosscompile the whole GNU opensource code?
--- Quote Start ---
originally posted by alex824@Nov 14 2005, 09:31 PM
what can i do?should i must use microtronix nios ii cross development kit to
crosscompile the whole gnu opensource code?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10973)
--- quote end ---
--- Quote End ---
Since you have a RedHat machine I&#39;d recommend you using the crosscompiler as shown discussed in the this (http://www.niosforum.com/forum/index.php?showtopic=2007#) thread which links to marc&#39;s crosscompiler (http://scorpius.homelinux.org/~marc/nios2.html) which I use for all my crosscompiling.
You can configure with ./configure --target=nios2-linux but you (probably) have to add "nios2" to the list of machines in the config.sub file in the section starting with:
case $basic_machine in:
Or something like that. I&#39;m currently on Windows so I&#39;m afraid I can&#39;t check.
Hope this helps.
Hi wqoossens ,thanks for you reply.
I will try my best effort till success.
