I build a nios system,first with a cpu. on_chip_memory , ssram, timer ,uart and it work well, it print the hello world to my uart.
then I add a flash and a tri_state_bridge to the nios system,compile and download it to my board, and also in the nios IDE I new a Hello World program and run it as hardware ,then it happen as follow: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Why? can anyone help me ,I am new to it. Thanks in advance.Link Copied
