12745 Discussions
can't see the information when uclinux start
when i start the uclinux,the iformation is:
Welcome To Altera SOPC Builder
Version 4.10, Built Wed Apr 7 10:42:15 PDT 2004
Welcome to the Nios II Development Kit
Version 1.0, Built Tue Apr 27 22:05:27 PDT 2004
Example designs can be found in
/cygdrive/d/altera/kits/nios2/examples
(Executing user startup script: d:/altera/kits/nios2/user.bashrc)
Microtronix Linux Extensions
Version 1.2, Built Wed Jul 27 3:46pm EST 2004
Welcome To Nios Development Kit
Version 3.10, Built Fri Aug 8 11:39:01 PDT 2003
/cygdrive/d/altera/kits/nios/examples
(You may add a startup script: d:/altera/kits/nios/user.bashrc)
[SOPC Builder]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: starting in terminal mode only (Control-C exits)
/etc/issue www.microtronix.com July 2004
Welcome to Linux on the Nios II
Nios2 login:
please tell me how to configure the kernel so that i can see the information like that:
Linux version 2.6.9-uc0 (skut@skut-xp2) (gcc version 3.4.1 (Altera Nios II 1.1
b137))# 5 Wed Mar 9 12:02:52 JST 2005
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14336k/16384k RAM, 0k/0k ROM (1548k kernel code, 309k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16 request
NIOS serial driver version 0.0 1.2 MBving up.
ttyS0 (irq = 4) is a builtin NIOS UARToad Address: 00000000
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksizeing Checksum ... Bad Data CRC
smc_probe: 50000 Khz Nios
12872
Using anticipatory io scheduler
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 48k freed (0x11b2000 - 0x11bd000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
thanks!!!!
I'm not really the Linux guy here, but I think these are the kernel configuration options:
Device Drivers --->  Character devices --->    Serial Drivers --->       <*> Altera JTAG UART support            Support for console on Altera JTAG UART
If you have Nios serial support selected (on the same settings page) make sure that "Support for console on Nios UART" is not selected. You should have only one device selected as the kernel console, this is where the kernel prints out its messages (boot messages, etc).
Dennis Scott
it`s ok ! thank you very much!!! serial has 4 choice , i ticked 1 3 4 .
