cannot build toolchain
I am trying to follow the instructions for building the uClinux by using the files contained in nios2linux-1.4.zip,
but the build0322.zip file is missig. This means I cannot run the build script and therefore can't start the build process. Can someone tell me where to get the correct zip file. I have serching for 4 hours now and cannot find it. :)
--- Quote Start ---
originally posted by hippo@Mar 25 2006, 09:06 PM
it is attached at the end of post#1.
http://forum.niosforum.com/forum/index.php...ype=post&id=130 (http://forum.niosforum.com/forum/index.php?act=attach&type=post&id=130
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13794)
--- quote end ---
--- Quote End ---
Thank you very much...
