12745 Discussions
close or change dynamicly the stdout in arria 10
Bar
Hello.
I want to block printf to my stdout driver which point to JTAG_UART set in the BSP editor. I try several options
 int file_dsc;
file_dsc = open("/dev/jtag_uart", O_RDONLY);
this way I was thinking that it can't write and printf doesn't go out.
I also after it this:
close(file_dsc);
to close the driver so printf doesn't go to output driver.
But for both of them I see print sin my terminal.
Is it possible to close it at all, and if so which function could do it?
Alternative if there is no function to do so I think on onther solution.
Is there a way in the code during run, to change the driver of stdout from JTAG_UART to NONE and back?
attach 2 pic of the setting I need.
Bar.
KellyJialin_Goh
I don't think we have any functions for this as usually, we would want to avoid printf blocking to the output terminal.
Hope this clarifies your doubts.
Best,
Kelly
KellyJialin_Goh
Greetings and welcome to Intel's forum.
I assume you mean to stop the printf to stdout driver for jtag_uart. I will attach a screenshot.
However, you are unable to change the driver of stdout from JTAG_UART to NONE and back during run time.
Thank you.
Kelly
KellyJialin_Goh
Attached is a screenshot to stop printf to stdout driver for jtag_uart by choosing none.
Thank you.
Kelly
Bar
Thanks Kelly.
The setting I know. but if I want to stop printing while I run why the close() (as in NIOS command), or fclose() (as in standart C) doesn't stop the printing (no metter which is the stdout? Is there onther command that I can use for stoping printng?
Bar.
KellyJialin_Goh
Best,
Kelly
KellyJialin_Goh
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly Jialin, GOH
