compile kernel errors
hello all!
when I compile the uclinux kernel ,I get some errors as following;please help me,thanks.
I use Quartus II 5.0 and NIOS II 5.0 and Microtronix uClinux 1.4 for nios2
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:72: error: `na_timer0' undeclared (first use in this function)
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:72: error: (Each undeclared identifier is reported only once
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:72: error: for each function it appears in.)
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c: In function `time_init':
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:113: error: `na_timer0_irq' undeclared (first use in this function)
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:115: error: `na_timer0' undeclared (first use in this function)
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:120: error: `np_timercontrol_start_mask' undeclared (first use in this function)
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:121: error: `np_timercontrol_cont_mask' undeclared (first use in this function)
/cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:121: error: `np_timercontrol_ito_mask' undeclared (first use in this function)
make[2]: *** [arch/nios2nommu/kernel/time.o] Error 1
make[1]: *** [arch/nios2nommu/kernel] Error 2
make: *** [_all] Error 2
make: Leaving directory
