hello all!
when I compile the uclinux kernel ,I get some errors as following;please help me,thanks. I use Quartus II 5.0 and NIOS II 5.0 and Microtronix uClinux 1.4 for nios2 /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:72: error: `na_timer0' undeclared (first use in this function) /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:72: error: (Each undeclared identifier is reported only once /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:72: error: for each function it appears in.) /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c: In function `time_init': /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:113: error: `na_timer0_irq' undeclared (first use in this function) /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:115: error: `na_timer0' undeclared (first use in this function) /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:120: error: `np_timercontrol_start_mask' undeclared (first use in this function) /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:121: error: `np_timercontrol_cont_mask' undeclared (first use in this function) /cygdrive/d/altera/kits/nios2_50/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu/kernel/time.c:121: error: `np_timercontrol_ito_mask' undeclared (first use in this function) make[2]: *** [arch/nios2nommu/kernel/time.o] Error 1 make[1]: *** [arch/nios2nommu/kernel] Error 2 make: *** [_all] Error 2 make: Leaving directoryLink Copied
Move to Linux PC, and follow the wiki,
http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux)
