12748 Discussions
compiling u-boot in nios2 ide
Has any one tried to compile u-boot in nios2 ide?
It solves the problem of manually making changes to the board specific header files.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
It solves the problem of manually making changes to the board specific header files.[/b]
--- Quote End ---
did you test that ? on what board ?
Warm Regards
Yes. I have tested it by compiling in cygwin for EP1C20. I tried to compile in IDE but got lot of errors. Had shortage of time so had to stop it.
Now I am trying to port it to a custom board with Nios2 and peripherals like RS 485, Lan chip - smsc 9111.
Hi shakthi,
It&#39;s not worth effort ... the source tree is designed to support multiple cpu architectures,
variants, and boards using the CLI in a unix environment.
You don&#39;t need the IDE for this -- you need to include the Nios system header
file in your u-boot tree ... and base the u-boot configuration macros on the Nios
system file macros.
--Scott
