- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi! Everyone!
Is it necessary to design configuration controller in custom board? If it just give stablity to system, is it mandatory or optional? Thanks! Regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gifLink copiado
6 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
OK, what exactly do you mean by configuration controller? EPCS?
IzI- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
If you want the board/system to boot into a functional state then, yes, some sort of config controller (EPCS, EPC, etc.) is necessary.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- originally posted by iztok.jeras@Jan 26 2007, 09:14 PM ok, what exactly do you mean by configuration controller? epcs?
izi
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20895)
--- quote end ---
--- Quote End --- Yeb, EPCS! But I wondered that controller is necessary when I use CFI. Using CFI, controller is unnecessary. thanks! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- originally posted by slacker@Jan 27 2007, 01:37 AM if you want the board/system to boot into a functional state then, yes, some sort of config controller (epcs, epc, etc.) is necessary.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20905)
--- quote end ---
--- Quote End --- Oh my 'nios' GOD. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thanks! very helpful!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- originally posted by jaeper+jan 28 2007, 05:27 pm--><div class='quotetop'>quote (jaeper @ jan 28 2007, 05:27 pm)</div>
--- quote start ---
<!--quotebegin-slacker@Jan 27 2007, 01:37 AM if you want the board/system to boot into a functional state then, yes, some sort of config controller (epcs, epc, etc.) is necessary.
--- quote end ---
--- Quote End --- Oh my 'nios' GOD. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thanks! very helpful! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20972)</div> [/b] --- Quote End --- Please keep in mind that you still need to load a hardware image from that CFI flash into your FPGA on power up. For that, you'll likely need a PLD. A lot of the Nios II Altera development kits use a "Max + Flash" combination and the config controller design is shipped with the Nios II EDS. I recommend this solution highly... Cheers, - slacker
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
If you are going for a simple and cheap solution than using only an serial SPI flash (EPCS) is better.
The epcs can hold both the hardware configuration image and the software. A parallel flash would be needed, if you need a very high read speed, or very large amounts of flash. EPCS and other SPI flash chips - sizes from 1Mbit to 64Mbit (usualy op to 512kB are used for the hardware image, the rest can be used for software and flash file systems) - read speed of 1MB/s is easily achievable IzI
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
