12748 Discussions
cpu_jtag_debug_module_reset - signal not active
Hi All,
I have a system with NIOS processor, and I'am using cpu_jtag_debug_module_resetrequest to some operations in my system, and everything is all right until Quartus 6.1 to 8.1 is used, in Quartus 9.0 there is problem whatever I do cpu_jtag_debug_module_resetrequest is not reseting system at debugger connection.
Did anyone had similar problem? Is there bug and I should use SP1 or Sp2?
cpu_jtag_debug_module_resetrequest - this signal is activating reset to the system at debugger connection, this is what I was able to determine from vhdl code :) .
I've managed to activate signal cpu_jtag_debug_module_resetrequest by using -r switch while downloading program, but I still can't understand why this switch wasn't needed in Quartus software version < 9.0
