12748 Discussions
create independant library under IDE
Hi all,
How can I compile a C library source files under the Nios II IDE?
I have the sources and the includes and I want to build the libray (files like *.a).
Best regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hi
Just go in Altera system manage library and make a *.a (static library). It is independent of *.ptf
Now create your C/C++ application using your NIOS IDE and link the Library name and its path to the current project using Linker option under "C/C++ build" option.
And you can get the help from NIOD IDE help also....
slsnios
You can create a "Managed Library Project" in NiosII IDE.
Following the steps below:
1.New a project
2.Choose Altera NiosII->Managed Library Project
The more info pls find in NiosII IDE->Help->Help Content, and search with the key word "Managed Library".
