12748 Discussions
display an image on my NEEK LCD
Hi all,
I want to learn how to use my NEEK's LCD display from uclinux.
For that reason, I want to use the lcd application that comes with the uclinux-dist (under user).
In menu xconfig, I enabled the lcd example under Misc Applications.
I download the image, start uclinux, and type lcd, I get the following output :
opening lcddma...returned -1
lcd.c is trying to open /dev/lcddma. I checked uClinux-dist/linux-2.6.x/include/asm-nios2/nios2.h and I found lcd_sgdma
I changed lcd.c to look for lcd_sgdma but kept having the same error.
Any pointers ?
Hi, multilane!
I have seen your posts, lcd_test are trying.
But KernelPanic become to, LCD is not displayed at all...
I'm using the next version.
HW: cycloneIII_embedded_evaluation_kit_standard.sof in neek_ocm_spi_mmu.zip.
SW: nios2-linux-20090929.tar with Stabele Linux Kernel & Drivers.
Using your source version, HW Could you tell me some information?
I appreciate if you help me.
Hi Yasuhiro and multilane,
I am exactly trying to do the same thing.
I use the HW neek_web_server_mmu and the SW with MMU (so nios2-linux-20090929.tar)
Then i do menuconfig
kernel/library/defaults selection
[*] Default all settings (lose changes)
[*] Customize Kernel Settings
NiosII Configuration --->
NiosII FPGA configuration (MMU_DEFAULT) --->
(X) CUSTOM_FPGA
Devices Drivers --->
Character devices --->
[*] Virtual terminal
Graphics support --->
<*> Support for frame buffer devices --->
<*> Altera framebuffer support
Console display driver support --->
[ ] VGA text console (NEW)
< > Framebuffer Console support (NEW)
The build is OK
But after download on the neek it do not start :
Here is the log
Linux/Nios II-MMU
init_bootmem_node(?,0x326, 0x0, 0x2000)
free_bootmem(0x326000, 0x1cda000)
reserve_bootmem(0x326000, 0x400)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line:
NR_IRQS:32
PID hash table entries: 128 (order: 7, 512 bytes)
Console: colour dummy device 80x25
console handover: boot [early0] -> real [tty0]
And it seems not to continue to start.
Nothing appears on the screen.
