dlopen()
Is there a way to build libdl? The java interpreter which I'm trying to build (jamvm) wants it. Normally this is a part of libc, but it doesn't seem to get build into microtronix uClibc. Do I have my LDFLAGS incorrect, or is there some way to build libdl.so
As far as I know, the nios2 tool chain Altera provides does not support PIC. Therefore, shared libraries is not supported.
Actually, I discovered that there is a dlopen provided by the standard libraries. At least you can compile with it and when linking, you don't get problems with resolving it. I haven't tried to actually use a program which uses dlopen() yet, though.
--- Quote Start ---
originally posted by clansdown@May 11 2005, 10:08 AM
actually, i discovered that there is a dlopen provided by the standard libraries. at least you can compile with it and when linking, you don't get problems with resolving it. i haven't tried to actually use a program which uses dlopen() yet, though.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=6859)
--- quote end ---
--- Quote End ---
If the intended application does not really need dynamic link (native) functionality,
one may consider link the native methods statically (like hte JAMVM internal native methods!)
