dma code problem
First I tried the DMA code example from the sw datasheet.
Than I used the single line codes.
I see the DMA register working and status on 0x800020 changing.
But somehow the sent data to the memory register 0x800000 does not change.
Any idea? Any good code example?
I did find out if you don't init the DMA the length register update can change the whole DMA registers.
# include <stdio.h># include "sys/alt_dma.h"# include "system.h"# include "altera_avalon_dma_regs.h"# include "altera_avalon_dma.c" // for init function
unsigned int *p = (unsigned int*)(0x400000);
void *pdma = (void*) DMA_0_BASE;
int main(void)
//init
IOWR_ALTERA_AVALON_DMA_STATUS(DMA_0_BASE, 0);
IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_0_BASE, 0);
//dma
IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_0_BASE, (int)p);
IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_0_BASE, 0x00800000);
IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_0_BASE, 20);
// wcon 1, rcon 0, leen 1, ween 0, Reen 0, I_en 1, go 1,32 bit 100 -> ok
IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_0_BASE, 0x029C);
printf ("Transfer successful!\n");
return( 0 );
Two suggestions:
1) Clear the DMA control register before doing anything else:
IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_0_BASE, 0);
(This ensures that the DMA init code within the HAL won&#39;t interfere with your operation).
2) Double-check that the DMA write master is connected to the slave at address 0x00800000.
Check your bus configuration in SOPC.
That caught me once. Everyting was running fine, except the data was not coming through.
It turned out to be a missing bus connection.
