dropbear compile error
Does any one get this error on compiling when enabling dropbear???
configure: error: *** zlib missing - install first or check config.log ***
I downloaded the nios2-linux-20090929.tar (linux-mmu) and did
./checkout and ./update
Then menuconfig and enabled dropbear.
Since I did not change H/W setting, I assume it is the default custom_fpga setting.
