The following piece of code should react to the falling edge of a 1-bit input pio and count the falling edges of a signal.
settings: no interrupt synchronous capture falling edge After one falling edge the loop is continously run. With a DSO it was detected that edge capture register was not cleared. How does one reset edge capture register properly? Where is my mistake? Thanks in advance. andy ------ while(counter<=end) { while(edge_capture==0) { edge_capture=IORD_ALTERA_AVALON_PIO_EDGE_CAP(BASE); } edge_capture=0; IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BASE,0x0); counter++ } ---Link Copied
