error at ide-flashprogrammer
can someone confirm this:
i have a custom board with a cyclone device at the jtag-chain at position 2, and
have just updated from niosII 1.01 to version 1.1.
Now if i open the flash programmer dialoge and select "target-connection", I can
select the dowload cable and the jtag device.
So far so good - if i select both to automatic, the command line flash programmer
issues "Error opening target hardware" - he can't find the cyclone device.
If, on the other hand the propper download cable and the right device is selected,
the same error occours -
because the device number is missing at the command line call !!
if i add the --device=2 (as set in the dialoge) at the xxx_programmer.sh file,
it works without any problem...
Is it just my installation or is there an error at the nios IDE?
thanks
stonie
