12748 Discussions
error occured when build the kernel
When I build the uClinux kernel(1.4),two errors occured:
this is the error information:
cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0 linux-2.6.x/drivers/ide/ide.c:262: error: for each function it appears in.)
cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0 linux-2.6.x/drivers/ide/ide.c: In function `init_ide_data':
cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0 linux-2.6.x/drivers/ide/ide.c:313: error: `na_ide_ide_irq' undeclared (first use in this function)
who knows how to solve the problem, please tell me, thanks very much!!
look forward to your reply!
try to disable IDE/ATA support in your kernel configuration, if you don't have this device.
also try the search function of this forum
--- Quote Start ---
originally posted by helmchen@Oct 10 2006, 05:51 PM
try to disable ide/ata support in your kernel configuration, if you don't have this device.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18622)
--- quote end ---
--- Quote End ---
It works, thanks very much!:)
