12748 Discussions
error running self compiled program
I compiled netcat with the nios2 toolchain. configure and make have done well. But when I try to ru the program I get the following error:
BINFMT: bad magic/rev (0x3000000, need 0x4)
What does this mean? Where is the problem?
Did you convert it from elf to flat format, using elf2flt?
no, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
the other problem is, when I run make, it runs the compiler for cywin. How can I use the nios toolchain instead?
