Hi, all:
I meet with a problem. Error occurs when I am downloading the .sof file in jtag mode with usb-blaster. Error Message: Error: Can't access JTAG chain, Error: Operation failed Two print circuit boards(PCB) are used. One is stratix II ep2s60 development board and another is Peripheral Circuit of the stratix board. They are connected though Pin header. I have found that error occurs when the boards are connected. Once they are disconnected, downloading .sof file will success. And I am sure the corresponding places of pins for jtag on the development board are not used in another PCB. What's wrong with my project? and what can I do then ? My project requires both of the PCBs, otherwise the system cannot work correctly! could anyone help!Link Copied
