error
I am with a composed architecture of a processor nios2, dma to controller, on chip memory and pious in the SOPC Builder. When software is compiled in IDE Eclipse with this architecture accuses the following error: Error: ` ALT_IRQ_NOT_CONNECTED ' undeclared (first uses in this function)[system_description/alt_sys_init.c ] Which is the cause of this error? E which is the solution for such problem?
Estou com uma arquitetura composta de um processor nios2, dma controller, on chip memory e pio no SOPC Builder.
Quando o software é compilado na IDE Eclipse com essa arquitetura acusa-se o seguinte erro:
Error: `ALT_IRQ_NOT_CONNECTED' undeclared (first use in this function)[system_description/alt_sys_init.c]
Qual é a causa desse erro? E qual é a solução para tal problema?
