extern pointer C bug or not?
Is:
extern cyg_uint8 gr_data_written[];
the same as?
extern cyg_uint8 *gr_data_written;
retrieving via
{ unsigned char *dp;
dp = gr_data_written;
my ecos gcc sets dp as the pointer if gr_data_written is declared the first way and as contents if declared the second way. Should it be the same?
The question is not clear enough.
You'd better show a simple example.
--- Quote Start ---
originally posted by david_cai@Oct 24 2006, 07:16 PM
the question is not clear enough.
you'd better show a simple example.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18886)
--- quote end ---
--- Quote End ---
Example:
// in declaration file
cyg_uint8 gr_data_written[5] = {1,2,3,4,5};
// in this other file# ifdef FIRSTWAY
extern cyg_uint8 gr_data_written[];# else
extern cyg_uint8 *gr_data_written;# endif
showme()
printf ("%x", (int) gr_data_written);
# ifdef FIRSTWAY
output of printf is a ptr "4A178";# else
output of printf is the value "1";# endif
I thought it was supposed to be the same either way, but it wasn&#39;t.
I think it is related to declaring a pointer vs. declaring an array.
Note, the *gr_data_written pointer is not declared anywhere nor initialized.
Thus, the result should be undefined.
When declaring, pointer and array are different.
Garland
--- Quote Start ---
originally posted by itntest+oct 26 2006, 05:23 pm--><div class='quotetop'>quote (itntest @ oct 26 2006, 05:23 pm)</div>
--- quote start ---
<!--quotebegin-david_cai@Oct 24 2006, 07:16 PM
you&#39;d better show a simple example.
--- quote end ---
--- Quote End ---
Example:
showme()
# ifdef FIRSTWAY
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18938)</div>
[/b]
--- Quote End ---
Not convinced yet.
Thoughts from anyone else?
Please try the following.
<span style="font-family:Courier">// in declaration file
cyg_uint8 *pData = gr_data_written; // initialize the pointer
extern cyg_uint8 gr_data_written[]; // good
extern cyg_uint8 *pData ; // good
</span>
Good luck!
Garland
