flash programmer
Does the Quartus flash programmer support to program raw binary images not created within eclipse IDE?
Okay...starting the FS2 console is the best way...
Hi klingler,
You can use bin2flash with nios2-flash-programmer as well.
Works great.
--Scott
Hi Scott,
It sounds like you've got some experience with bin2flash. What are the pros & cons of using bin2flash vs. the zipfile system?
And assuming you're using bin2flash, how does the Nios code know where to address the data? Is there some way to generate a header file with the base address, or something like that?
thanks,
Carol
Hi Carol,
bin2flash is just a utility to convert a binary file into a flash file. The flash file
is basically an S-Record file you can use with the flash programmer. The Read-Only
Zip Filing System on the other hand, is a file system supported by the HAL. It lets
you access files stored in an image in flash memory.
bin2flash and nios2-flash-programmer is handy when you're using a file system like
cramfs or jffs2 ... or when you just want to program raw data into flash somewhere.
How your program knows where to find the data is up to you (or the underlying
drivers ... like mtd in the linux kernel for example).
> like that?
Sure ... you can do it however you like. Even a hardcoded base address will do.
It all depends on what you're trying to accomplish and your run-time environment.
WRT the zipfile stuff, I've never used it ... but for cramfs/jffs2 they're all basically
just hardcoded addresses in the mtd mapping drivers.
--Scott
