frame buffer
Hello hippo and all NiosII users!
I compiled uClinux-dist with frame buffer (as wrote on nioswiki) and loaded it in my custom board(flash,sdram,vga_controller,uart,eth). Linux is loaded(I see it in Shell) but screen is empty, there is no signal to LCD(without Linux lcd operates correct).
Need I some adjustments or changes in frame buffer driver if I use my custom board? Where is stored initialization data for VGA_controller (base address).
Thanks a lot!
Do you see this message in booting?
fb0: Altera frame buffer device, using 600K of video memory
The framebuffer driver is,
linux-2.6.x/arch/nios2nommu/drivers/altfb.c
You may look at altfb_probe(), which init the hardware.
You may need to use scope or signal-tap to check the output pins of the vga controller, HS,VS, etc.
You may need to modify the vga component to meet your LCD timing.
