12748 Discussions
gcc 4.1 toolchain and kernel compatibility
Hi all,
I successfully compiled the 4.1 toolchain and also the most recent kernel from
the git (2.6.35). Unfortunately they don't work together. I compiled a simple
hello world and don't see any output. The executable is tagged to be for
kernel 2.6.21. Does that mean it won't work with more recent kernels?
If so, where do I get the kernel sources from?
Thanks for any insights ...
- Johannes
Stupid me the kernel is included in the gcc-4.1 toolchain dir. Sorry for bothering you ...
- Johannes
You can get the linux sources from the git repository at sopc.et.ntust.edu.tw (as mentioned in the wiki).
OTOH it probably won't make a difference as the new system calles hooked up there won't be used in the glibc version used in the current toolchain.
Hi Johannes,
How did you succeed in rebuild the gcc 4.1 toolchain? Did you follow a wiki?
Where did you find the sources? niosftp.com doesn't work anymore...
Thanks in advance...
