gcc-4.1 toolchain on Ubuntu
Hi all,
I just successfully built the gcc-4.1 toolchain on my Ubuntu box, it should be mentrioned
that gawk is required for building the toolchain (glibc does not compile with mawk which
is the default awk on Ubuntu)
Hope that helps ...
- Johannes
Never ran into this issue, on my system I have gawk, but I've gone through a few upgrades. What version of Ubuntu?
I use Ubuntu 9.10.
- Johannes
Looks like 10.04 changed to gawk by default, but I updated the wiki page anyway.
Thank you for updating the Wiki, I also found that after installing gcc-4.3 packages,
a symbolic link is required to make the build script happy:
sudo ln -s /usr/bin/gcc-3.4 /usr/bin/gcc34
All the best ...
- Johannes
