hardware run problem
I am running a modified version of the microtronix loopback example on the cyclone ep1c20
When i try to run the loopback program on the hardware i get this error:
There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.
What is causing this error??java script:emoticon(':(')
smilie
Winnie
Winnie,
My 2Cents.
Sometimes you get this error if the CPU you selected in SOPC does not include a a debugger.( Use atleast Level 1 in the JTAG debug module port).
-Baycool
I check my cpu settings in the SOPC and level 1 JTAG debug module is selected.
what other settings and/or code can cause this problem??
PLEASE HELP http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Winnie
Are you sure that you&#39;re downloading the right SOF file (hardware configuration) before attempting to debug the design? If you&#39;re not, then you&#39;ll see the problem you have described.
Funny thing is
It works on the wrong SOF file. When I download the kitchensink.sof, which has a lot of other additional components that are not being used, it works. But when i download the SOF for the hardware configuration, it doesn&#39;t work. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
HELP http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif
Winnie
That&#39;s really bizarre...
In the Nios II IDE, did you create the following for the new project (not the kitchensink one):
* Library
* Application
* Debug Session
Or, are you using the old software project settings with your new system?
I took the old loopback project, from microtronix, which was running Nios II with legacy SDK support, and updated to run with HAL
In SOPC, I did the following:
*removed the rom and increase the on-board ram size.
*added a JTAG UART
*change the CPU setting to include a lv. 1 debug module
*disabled the legacy SDK support
In Nios II IDE, I did the following:
*start a new project (C++ application with a new system library)
*modified the original loopback.c code (change the headers, replace API calls with HAL and ANSI C calls, changed register access to use HAL I/O Macros, etc.)
Did I miss something??
Winnie
