12748 Discussions
header and code files are not included in bsp
PHeri1
I have included a component from opencores into my Platform Designer.
All 'library' paths are set in Quartus and the project compiles successfully.
But when I import the sopcinfo file into Nios II Eclipse Mars.2, the .h and .c files are never included in the bsp file. So they are also missing the the .elf file.
When I rightclick on the opencores component in the Platform Designer and choose Detail and Open Component Folder...
I see all the *.v files, a HAL and an inc folder.
All the files are installed on my computer in the folder:
C:\intelFPGA_lite\19.1\ip\opencores\i2c_opencores
Hazlina_R_Intel
My name is Hazlina. I am the senior manager for the technical support team supporting this forum, I apologize that we had to backlog this case and didn't answer this in-time. Is your question still outstanding or has it been resolved? Let me know so that I can decide the appropriate course of actions. Thanks.
PHeri1
Hi Hazlina,
This question is still active. I hope you can help me.
Hazlina_R_Intel
Noted. I will assign this to an engineer to help. You shall receive a response shortly. Thanks.
EricMunYew_C_Intel
Hi, Peter
You may manually add the .h and .c files of your IP in your Nios II SBT, add to Project Explorer -> your _bsp folder -> drivers -> inc/src, and rebuild your project file.
Best regards
Eric
EricMunYew_C_Intel
Hi, Peter
Can we close the case if it is solved ?
Eric
