help generate the zImage
I'm trying to make uClinux's zImage by executing command "make" after i have done the "make menuconfig" and "make vendor_hwselect" successfully, but the process always executing the some code, the following code are part of it:
2 DGRAM 14288 unix 2 DGRAM 14381 unix 3 DGRAM 9624 unix 3 DGRAM 9623 unix 2 DGRAM 9398 unix 2 DGRAM 9397 zip error: Nothing to do! (6/ddp.zip)Active Internet connections (w/o servers) Proto Recv-Q Send-Q Local Address Foreign Address State Active UNIX domain sockets (w/o servers) Proto RefCnt Flags Type State I-Node Path unix 26 DGRAM 1796 /dev/log unix 2 DGRAM 1805 /run/systemd/shutdownd unix 2 DGRAM 1861 @/org/kernel/udev/udevd unix 2 DGRAM 8564 /run/systemd/notify unix 3 STREAM CONNECTED 135793 /home/hanxu/.pulse/03150a200ccbe5c4977b361c00000014-runtime/native unix 3 STREAM CONNECTED 136789 unix 3 STREAM CONNECTED 134120 @/tmp/dbus-2sNK3v4L unix 3 STREAM CONNECTED 134119 unix 3 STREAM CONNECTED 134636 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 134097 unix 3 STREAM CONNECTED 134083 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 134082 unix 3 STREAM CONNECTED 134080 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 134594 unix 3 STREAM CONNECTED 134593 @/tmp/.ICE-unix/1632 unix 3 STREAM CONNECTED 134592 unix 3 STREAM CONNECTED 134071 @/tmp/.X11-unix/X0 unix 3 STREAM CONNECTED 134549 unix 3 STREAM CONNECTED 111122 /var/run/dbus/system_bus_socket unix 3 STREAM CONNECTED 112010 unix 3 STREAM CONNECTED 111116 /tmp/orbit-hanxu/linc-12f2-0-2a10c26aec2c unix 3 STREAM CONNECTED 112009 unix 3 STREAM CONNECTED 112008 /tmp/orbit-hanxu/linc-6b4-0-61155ec35924a unix 3 STREAM CONNECTED 111114 unix 3 STREAM CONNECTED 111095 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 111997 unix 3 STREAM CONNECTED 111090 @/tmp/dbus-2sNK3v4L unix 3 STREAM CONNECTED 111993 unix 3 STREAM CONNECTED 111083 unix 3 STREAM CONNECTED 111082 unix 3 STREAM CONNECTED 111080 @/tmp/.ICE-unix/1632 unix 3 STREAM CONNECTED 111970 unix 3 STREAM CONNECTED 111956 @/tmp/.X11-unix/X0 unix 3 STREAM CONNECTED 111955 unix 3 STREAM CONNECTED 84577 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 84576 unix 3 STREAM CONNECTED 32551 @/dbus-vfs-daemon/socket-1VOtJCXs unix 3 STREAM CONNECTED 32550 unix 3 STREAM CONNECTED 32552 @/dbus-vfs-daemon/socket-1of8MTTR unix 3 STREAM CONNECTED 32549 unix 3 STREAM CONNECTED 32542 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 32541 unix 3 STREAM CONNECTED 32425 @/tmp/dbus-2sNK3v4L unix 3 STREAM CONNECTED 32424 unix 3 STREAM CONNECTED 32423 @/dbus-vfs-daemon/socket-VxPLb4zk unix 3 STREAM CONNECTED 32422 unix 3 STREAM CONNECTED 32421 @/dbus-vfs-daemon/socket-DMo2AJtV unix 3 STREAM CONNECTED 32420 unix 3 STREAM CONNECTED 31633 @/dbus-vfs-daemon/socket-FMBnlpZE unix 3 STREAM CONNECTED 31632 unix 3 STREAM CONNECTED 31634 @/dbus-vfs-daemon/socket-0kWNSiNm unix 3 STREAM CONNECTED 31631 unix 3 STREAM CONNECTED 31625 @/tmp/dbus-accCQ7gn3g unix 3 STREAM CONNECTED 32412
ps:I use the .ptf file provided in wiki and in "make menuconfig" I choose Default all Settings.
can anybody help me?
thanks in advance.
That text looks like the output from 'netstat'.
I have known the answer. the zImage must be make under linux's file system.
