help on SDRAM
Hello.
I have a big problem with my board.
My board has a EP1CQ240C6, one flash Intel E28F128, one SDRAM MT48LC4M32, one EPCS4 and a LAN91C111. The CPu clock is 50 MHz.
I have made a serious mistake when I design the board. I used the PLL pins as general I/O pins, so the PLL can't be used any more. But the SDRAM's clock is from the PLL. I've no idea but use the 50MHz clock as the SDRAM'clock source.
When I build a "hello word" program, it can run in the onchip RAM but can't run in the SDRAM. Maybe the SDRAM can't work.
How should I choose the clock for the SDRAM without PLL? And the frequency?
thanxxx!
Hi sol,
I think that your problem is not the frequency of the clock to SDRAM but the phase shift between this clock and the processor clock: u must set a phase shift between these clocks, we used 3.5 ns in a EP1C20 board. I think u could realize it in VHDL...
Hi Soin£¬ thank u for your answer http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Maybe the phase shit is the problem, but how can I generate a phase shift without PLL.
For example , the main clock is 50MHz, if I want to get the 3.5ns, the phase shift is approximate 65 degrees.
In the file "sdram.vhd", I didn&#39;t see the content about the phase shift.
sol *_*
In general, u can design a phase shift using a faster clock to re-sample your clock. But having a 50 MHz clock u have 20 ns period, so if u generate a slower clock, u have a maximum resolution shift of 10 ns and u can&#39;t realize the 3.5 ns shift.So it&#39;s a problem...
Can u reconfigure your I/O pins to use PLL? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hi Soin, I am back.
Maybe I can try it.
"This PLL introduces a phase-shift which compensates for board-level delays in the clock network. Other boards may require different settings."
Why need a compensate for board-level delays? And how to calculate the delays of my board?
I am beginner ......
Thank u http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hi sol,
While not SDRAM-specific, there is a document in Nios II 5.0 which may help you understand how to calculate phase-shift values and determine how fast you can run SDRAM without using a PLL for phase-shifting. The document describes the new SSRAM interface in Nios II 5.0 and is "ssram_interface_readme.html" in the Nios II installation&#39;s &#39;documents&#39; folder.
You should study carefully the first section that describes the memory interface with no phase shift -- it will show you how to calculate the maximum speed which you can run with no phase shift. You will need:
1. To obtain the data sheet for your SDRAM and examine timing parameters (Tsu, Tco for all inputs, worst-case)
2. Look at the quartus timing analysis report for Tco and Tsu times for all pins to and from SDRAM
3. Perform timing analysis to see what f-max you can run at with no phase shift
Important note: Even without a PLL there will be a phase-relationship between FPGA (Avalon) clock and the clock you drive from the FPGA to SDRAM. You should be able to find this delay in the Quartus Tco report.
Good luck!
How about clocking the sdram with the non altered 50 MHz and use the PLL to shift the NIOS clock 3.5ns in the other direction ?
