12747 Discussions
help on developement board for connection ethernet
hello, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif I would wish to use the Ethernet port with quartus and sopc builder, which are the elements has to add put has share the LAN 91C111. (cpu, memory SSRAM, timer....) I use the development board will altera
http://www.altera.com/products/devkits/alt...-nios-2c35.html (http://www.altera.com/products/devkits/altera/kit-nios-2c35.html).
I would like to use the memory ssram in order to memorize data and to send them on the Ethernet port. I know nothing in programming under nios IDE.
can you help me thank you very much http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
