i have tried a lot to find the 16*2 lcd driver in the core of uclinux (in the menuconfig).
but until now i can't find such a option. if somebody knows how to add it to the core ,can you help me? and i also tried to write a driver of it, but it didnt word well. i'd like to share it to you , and i hope anybody can point what the problem is in the file.Link Copied
#include <linux/module.h># include <linux/errno.h># include <linux/cdev.h># include <linux/config.h># include <linux/types.h># include <linux/errno.h># include <linux/miscdevice.h># include <linux/slab.h># include <linux/ioport.h># include <linux/fcntl.h># include <linux/mc146818rtc.h># include <linux/netdevice.h># include <linux/sched.h># include <linux/delay.h>
# include <asm/io.h># include <asm/uaccess.h># include <asm/system.h># include <linux/delay.h> # define LCD_On 1# define LCD_Off 2# define LCD_Clear 3# define LCD_Reset 4# define LCD_Cursor_Left 5# define LCD_Cursor_Right 6# define LCD_Disp_Left 7# define LCD_Disp_Right 8# define LCD_Get_Cursor 9# define LCD_Set_Cursor 10# define LCD_Home 11# define LCD_Read 12# define LCD_Write 13# define LCD_Cursor_Off 14# define LCD_Cursor_On 15# define LCD_Get_Cursor_Pos 16# define LCD_Set_Cursor_Pos 17# define LCD_Blink_Off 18 # define kLCD_IR na_lcd_16207_0# define kLCD_DR (na_lcd_16207_0 + 8) # define LCDWriteData(x) outl(x , kLCD_DR)# define LCDWriteInst(x) outl(x , kLCD_IR) # define LCDReadData inl(kLCD_DR)# define LCDReadInst inl(kLCD_IR) # define Major 250 static int Device_Open = 0; static int lcd_16207_ioctl(struct inode *inode,struct file *filp, unsigned int cmd,unsigned long arg); static int lcd_16207_open(struct inode *inode,struct file *filp) { static int counter = 0; if(Device_Open)return -EBUSY; Device_Open++; printk("You have open the device %d times\n",counter++); return 0; } static int lcd_16207_release(struct inode *inode,struct file *filp) { Device_Open--; printk("You have release the device\n"); return 0; } static int lcd_16207_ioctl(struct inode *inode,struct file *filp, unsigned int cmd,unsigned long arg) { volatile unsigned long display; switch (cmd) { case LCD_On: if (copy_from_user (&display, (unsigned long *) arg, sizeof(display))) return -EFAULT; LCDWriteInst(display); break; case LCD_Off: if (copy_from_user (&display, (unsigned long *) arg, sizeof(display))) return -EFAULT; LCDWriteData(display); break; default: return -EINVAL; } return 0; } static struct file_operations lcd_16207_fops={ .ioctl = lcd_16207_ioctl, .open = lcd_16207_open, .release = lcd_16207_release, }; static int lcd_16207_init(void) { int ret = register_chrdev(Major,"LCD_PIO",&lcd_16207_fops); if(ret<0) { printk("Registering the device failed with %d\n",Major); return Major; } printk("You have init Device %d\n",Major); return 0; } static void lcd_16207_exit(void) { if(unregister_chrdev(Major,"LCD_PIO")) printk("exit failed"); } module_init(lcd_16207_init); module_exit(lcd_16207_exit); MODULE_AUTHOR("Andrew Bose"); MODULE_LICENSE("GPL");- Mark as New
I am also looking at getting the LCD running, but i have absolute no idea. Which ptf do you use ? I use the std_2c35.ptf, is that enough ? Or do i have to use the full featured one ? Can you also elaborate how what state the code is in ? Is it working ? I need some help and guide here. --- Quote Start --- originally posted by snail1@Aug 8 2006, 09:06 PM #include <linux/module.h># include <linux/errno.h># include <linux/cdev.h># include <linux/config.h># include <linux/types.h># include <linux/errno.h># include <linux/miscdevice.h># include <linux/slab.h># include <linux/ioport.h># include <linux/fcntl.h># include <linux/mc146818rtc.h># include <linux/netdevice.h># include <linux/sched.h># include <linux/delay.h># include <asm/io.h># include <asm/uaccess.h># include <asm/system.h># include <linux/delay.h>
# define lcd_on 1# define lcd_off 2# define lcd_clear 3# define lcd_reset 4# define lcd_cursor_left 5# define lcd_cursor_right 6# define lcd_disp_left 7# define lcd_disp_right 8# define lcd_get_cursor 9# define lcd_set_cursor 10# define lcd_home 11# define lcd_read 12# define lcd_write 13# define lcd_cursor_off 14# define lcd_cursor_on 15# define lcd_get_cursor_pos 16# define lcd_set_cursor_pos 17# define lcd_blink_off 18
# define klcd_ir na_lcd_16207_0# define klcd_dr (na_lcd_16207_0 + 8)
# define lcdwritedata(x) outl(x , klcd_dr)# define lcdwriteinst(x) outl(x , klcd_ir)
# define lcdreaddata inl(klcd_dr)# define lcdreadinst inl(klcd_ir)
# define major 250
static int device_open = 0;
if(device_open)return -ebusy;
device_open++;
printk("you have open the device %d times\n",counter++);
return 0;
device_open--;
printk("you have release the device\n");
return 0;
switch (cmd) {
case lcd_on:
if (copy_from_user
sizeof(display)))
return -efault;
lcdwriteinst(display);
break;
case lcd_off:
if (copy_from_user
sizeof(display)))
return -efault;
lcdwritedata(display);
break;
default:
return -einval;
return 0;
int ret = register_chrdev(major,"lcd_pio",&lcd_16207_fops);
if(ret<0)
printk("registering the device failed with %d\n",major);
return major;
printk("you have init device %d\n",major);
return 0;
if(unregister_chrdev(major,"lcd_pio"))
module_author("andrew bose");
module_license("gpl");
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17462)
--- quote end ---
--- Quote End ---
