hi,I have the same problems. There may be some wrong with the server. You may get a lower version on the Internet. good luck.
wangweike- Mark as New
does nios-linux-20100621 support DE2-70 board?
there are only two choices 3c120 or NEEK- Mark as New
--- Quote Start --- does nios-linux-20100621 support DE2-70 board? there are only two choices 3c120 or NEEK --- Quote End --- it support it refer to the nioswiki,and you can creat the system for your board
