12748 Discussions
how can i include fun.c in nios
hi everyone
i put some functions in fun.c, try to make the main.c easy to read.
how can i include fun.c in main.c? where should i put the fun.c?
i tried to put it in the bsp floder, but the eclipse build the project with many errors# include "alt_types.h"
//#include "altera_avalon_pio_regs.h"# include <io.h># include "sys/alt_irq.h"# include "system.h"# include <stdio.h># include <unistd.h># include "timer_fun.c" // this is my own fun# include "ft245_driver_fun.c" // this is my own fun# include "biss_driver_fun.c" // this is my own fun
Print the code in a paper, then paste into the Nios package with a sticker
If you are asking a question so basic, you need to read up on the NIOS software development process. There are several intro documents on the Altera website.
You can include that into your app folder instead. You can run the command to update the makefile "nios2-app-update-makefile --add-src-files <filenames>"
alternately, you may consider to glue the file printed on the paper straight to the ground, this is called include as well.
